right rear window wont go up or down. I hear a click when button is depressed to activate
Oct 22, 2010 at 3:57 PM
SATURNTECH9
CERTIFIED EXPERT
If you hear the click coming from the door then you most likely have a bad window motor.You will need to remove the door panel and see if you have power and ground to the window motor.
