2002 Cadillac DTS PCV Valve
2002 CADILLAC DEVILLE DTS
68,000 MILES • V8 • 2WD • AUTOMATIC
HENRY KENNEDY
This is my first time and it is all a little confusing. I just chaged my paypal account to my new bank so that you get payed.
Question: I just bought a new PCV valve at the dealer and can't find where it goes after I remove the engine cover. Any ideas?
Nov 24, 2009 at 1:34 PM
FACTORYJACK
  • 4,159 POSTS
Crankcase Ventilation System Inspection/Description
A crankcase ventilation system is used to consume crankcase vapors created during the combustion process instead of venting them to the atmosphere.
Fresh air is supplied through a filter to the crankcase, the crankcase mixes the fresh air with the blow-by gases and then passed through a positive crankcase ventilation (PCV) orificed tube into the intake manifold.
The PCV orificed tube restricts the flow rate of the blow-by gases using a 3 mm (0.118 in) (a) orifice located at the end of the tube. If abnormal operating conditions arise, the system is designed to allow excessive amounts of blow-by gases to back flow through the crankcase vent tube into the throttle body in order to be consumed by normal combustion.
Nov 24, 2009 at 10:00 PM
HENRY KENNEDY
I had a rough idea as to the PCV Valve function, but where is the little thing located? I can't find it.
Nov 25, 2009 at 12:01 PM
FACTORYJACK
  • 4,159 POSTS
It was written in your other post. It is in the rear cam cover, non-serviceable orifice.
Nov 27, 2009 at 9:27 PM
