The dash says check coolant level, but it is on the normal mark. And gives a beeping sound when driving.
Jun 19, 2010 at 10:43 PM
FACTORYJACK
CERTIFIED EXPERT
Had it been low and coolant was added? The sensor for coolant level is in the tank. Sometimes it sticks, and the tank may need replaced. You can try rapping on the tank pretty firmly, although not enough to break it. I use a rubber mallet when I try it. Alot of times it works, but not always.
