2001 Cadillac DTS Dash gauges flicker on and off and give f
2001 CADILLAC DEVILLE DTS
46,000 MILES • V8 • FWD • AUTOMATIC
JIMBEEKS
Dash lights flicker on and off and give flase readings. Example, tire pressure reads 3 p lbs, engine says says stop engine hot, transmission overheated stop, fuel gauge says low range and its full.
All these are flase and inst. panel cuts off completely and then on again...all other electrical stuff works ok.
Checked battery connection under rear seat , ok.
Any suggestions besides a rip off dealer?
Dec 6, 2009 at 10:12 AM
FACTORYJACK
  • 4,159 POSTS
Try using this, sorry as there are no illustrations with it.
#02-06-03-007: No Start, No Crank, I/P Lamps Illuminated (Batery, Batteries, Generator, Alternator, Gauges, SES, SIR, Brake, Security, Theft, ABS, Hot, Light, Lamp) DIC Messages (Repair Loose Generator to Engine Mou - (Jul 26, 2002)
Subject: No Start, No Crank, I/P Lamps Illuminated (Battery, Batteries, Generator, Alternator, Gauges, SES, SIR, Brake, Security, Theft, ABS, Hot, Light, Lamp), DIC Messages (Repair Loose Generator to Engine Mounting Bolts and/or Wiring)
Models: 2001- 2002 Cadillac DeVille, Seville
Condition
Some customers may comment on one or more of the following conditions:
• Intermittent illumination of one or more of the following Instrument Cluster panel warning lamps.
• SES light
• Generator light
• SIR light
• Brake light
• Security/Theft light
• ABS light
• Hot light
• Gauge readings which seem to be incorrect.
• Erratic RPM display on the tachometer.
• Engine is difficult/hard to start.
• Engine will not crank.
• Check Generator displayed on the Driver Information Center.
• The transmission shifts hard.
• Noise underhood (growl, rattle, hiss, tapping, grinding).
Cause
This condition may be caused by the following:
• Loose/missing generator to engine mounting bolts
• Chassis to engine and generator ground mounting bolt loose
• Loose generator wiring connection
Correction
Use the following procedure to access the generator for repair of loose mounting bolts and/or wiring:
Place the vehicle in position to be lifted by a hoist.
Remove the rear seat cushion to gain access to the battery.
Disconnect the negative battery cable.
Open the hood.
Remove the ground cable attaching bolt from the right front chassis rail.
Raise the vehicle.
Remove the bumper to radiator support close-out panel.
Remove the generator attaching bolt #2.
Remove the ground cable from the vehicle and clean both ends of the cable if there is any indication of corrosion.
Important: Tightening the mounting bolts in an improper sequence may result in a loose ground.
Inspect for missing mounting bolt(s) #1 and #3. Replace them as necessary.
Tighten
Tighten the generator attaching bolt(s) #1 and #3 to 50 N·m(37 lb ft).
Reposition the ground cable to the generator and install the generator attaching bolt #2.
Tighten
Tighten the #2 generator attaching bolt to 50 N·m(37 lb ft).
Position the protective boot of the generator BAT output terminal aside.
Remove the retaining nut from the BAT terminal.
Inspect and clean any corrosion, as required, from the wire terminal to generator terminal interface.
Reinstall the wiring harness to the BAT terminal.
Tighten
Tighten the BAT terminal retainer to 12.5 N·m(111 lb in).
Reposition the BAT terminal protective boot back into proper position.
Reinstall the lower bumper to radiator support close-out panel.
Lower the vehicle.
Reinstall the chassis end of the ground cable into position.
Install the engine ground cable bolt into the chassis retainer.
Tighten
Tighten the engine ground cable bolt to 50 N·m(37 lb ft).
Reconnect the negative battery cable to the battery.
Tighten
Tighten the battery cable retainer to 17 N·m (13 lb ft).
Refer to Corporate Bulletin Number 02-06-03-006 for proper testing procedures of the Battery and Generator.
Reposition the rear seat cushion.
Start the vehicle and observe the Drivers Information Center for messages.
If the tire pressure monitor message is displayed, refer to Tire Pressure Monitoring Sensor Programming in SI.
Set the clock to the correct time for the customer.
Dec 7, 2009 at 10:26 PM
