2000 Cadillac DTS no oil pressure
2000 CADILLAC DEVILLE DTS
12,000 MILES • V8 • 2WD • AUTOMATIC
HABSOFBORG
low oil pressure light came on after car sat for two weeks. mechanic blew oil threw system, thinks screen in oil pan is clogged or oil pump is bad. says engine needs to be pulled to fix?
Nov 18, 2008 at 7:18 AM
ERNEST CLARK
  • 1,730 POSTS
So what is your question??? Are you saying you don't trust the word of your mechanic???
If so, you should go get a second opinion. There's no way I could test your engine myself, but a "Low oil light" needs to be verified with a oil pressure gauge.
If the oil pressure is low, then there's either something clogging the system, the pump is blocked, or the pump is bad.
Mar 13, 2010 at 3:01 PM
