2000 Cadillac DTS Changing power steering pump?
2000 CADILLAC DEVILLE DTS
DADOC42
Steering problem
2000 Cadillac DTS V8 Two Wheel Drive Automatic
How do you get the pulley off and how many bolts are on the pump?
Apr 18, 2009 at 2:54 PM
FACTORYJACK
  • 4,159 POSTS
The pulley is a press fit, requires a p/s pulley puller. Often times there is an installer included with a new pump. There is only one bolt, 13mm head, down the rear bank side of the pump. You will then have two bolts for the bracket, accessible when the pulley is removed.
Apr 19, 2009 at 12:02 PM
RAYDON55
The pulley cost around $14 pulley remover cost around $81.77 both at advance auto. If you are replacing the pump cost wise I'd go with the old CROW bar. To press the pulley back on use the bolt and a 1" socket tighten until the required space on the shaft. Oh ,works best with belt on. Just my 2 cents.
Jun 17, 2012 at 12:24 AM
