Engine Mechanical problem
1960 Cadillac DTS V8 Two Wheel Drive Automatic unknow miles
I just bought this old caddy When I started it it ran fine for 30 min. then blew a pin hole in the heater hose. old rusty water. I took it to a mechanic to see if the block was cracked or a blown head gasket.they checked out the car and said it was fine. they flushed radiator replaced the heater hose. changed the oil and said car is fine. when I just checked the oil its golden but has a little light gray material on the very end of the dipstick .another mechanic said it might be bearing material. change the oil again with a B/G product.and check again. The car runs fine right now.How can I be sure Motor is GOOD?
Jun 1, 2009 at 10:47 AM
