Low idle and pulls at a stop.
CADILLAC DEVILLE
CTORRES1031
I recently had the engine rebuilt in my 1966 Deville (429ci). When I drive, the first 15-20 minutes are fine, but the idle drops to the point of shutting off when I stop. Also, the car pulls severely when at a stop causing the car to jerk badly back and foward. Any ideas why?
Oct 30, 2007 at 12:15 AM
What type of ignition and fuel system do you have or its been modified.
Oct 30, 2007 at 1:00 AM
You need to check the dwell angle of this igntion system or adust the point gap of the contact point and its condenser and also the vacuum/centrifugal advance diaphgram. whether its advancing and retarding the ignition timing.
I don't think you have A PCV system-its down draft type.
Dwell or Cam Angle:
An ignition timing term associated with older vehicles that used traditional point-type ignition systems. The length of time, expressed in degrees of distributor rotation that the breaker points are held closed.
Oct 30, 2007 at 11:49 PM
