climate control power module
CADILLAC DEVILLE
SLLY1791
1988 cadillac deville 4.5 liter 218,000 miles. i recently put a new blower motor in car now it wont shut off unless i unhook it or disconnect the battery cable. is there a relay or something else i need to do after replacing blower motor or do you think it has something to do with the climate control power module?
Feb 19, 2007 at 12:03 AM
CHEVY22
  • 1,375 POSTS
i would check the relay it is located in the d position of the relay center, the relay may be stuck on , or it could be a problem with the climate control module , i would check the relay first and go from there
thanks
Feb 19, 2007 at 10:20 AM
