2006 Cadillac Deville how to change front turn signal bulb
2006 CADILLAC DEVILLE
64,000 MILES • V8 • FWD • AUTOMATIC
MWHITE99
MEMBER
FOLLOW
how do i get to turn signal bulb ? owners manual said to to take to dealer for all bulb replacements !
Dec 14, 2008 at 5:14 PM
BLUELIGHTNIN6
CERTIFIED EXPERT
Hello
Could you please specify wether this is a front or rear turn signal, as well as which side the signal bulb is on?
Dec 14, 2008 at 5:37 PM
MWHITE99
MEMBER
Hello- the cadilac is a 2006 DTS , the left front turn signal bulb is burned out , I found two bolts in top of light assm. are there more bolts or does the assm. pull up ?
Thanks in advance
Dec 14, 2008 at 7:50 PM
BLUELIGHTNIN6
CERTIFIED EXPERT
Thanks for that info.
There will be one more bolt before you can pull it out and disconnect wiring.
