Ok what you have is a hub assembly so it is a total replacement of the front hub. So what you do is first loosen the front axle hub nut then the wheel lug nuts. Now lift and support the car on the side that you need to replace. Now remove the wheel and the axle nut. Now remove the brake caliper and the support it with a bunge cord or something (don't let it hang by the brake line). Now remove the front brake rotor. From the the back side there are three bolts remove those then remove the hub assembly and put the new one back in reverse order. Here is a pic of what you are going to replace. Hope this helps.
Jul 14, 2009 at 9:59 AM
