Washer Pump Replacement
Removal Procedure
Drain the washer solvent container.
Remove the right front fascia extension. Refer to Front Bumper Fascia Extension Replacement in Bumpers.
Disconnect the washer hose from the washer pump.
Disconnect the electrical connector from the washer pump.
Remove the washer pump from the washer solvent container.
Installation Procedure
Install the washer pump in the washer solvent container.
Connect the electrical connector to the washer pump.
Connect the washer hose to the washer pump.
Install the right front fascia extension. Refer to Front Bumper Fascia Extension Replacement in Bumpers.
Fill the washer solvent container.
Sep 8, 2009 at 11:15 PM
