My right headlight burned out and I got another bulb to replace it. My question is, How do I get this bulb in. Thank You
Jan 30, 2009 at 9:59 AM
FACTORYJACK
CERTIFIED EXPERT
Pull the upper sight shield held on with 4-6 push pin retainers. If the retainers are original, the centers push down a step, and lift on the shield to dislodge them. the lamp housing is held in with three 10mm bolts all seen from the top. A cover is removed, and the bulb/socket. Don't touch the glass envelope on the new bulb, or it won't last.
