how do you change the battery on a cadillac deville. the car won't crank over when charging battery.
Oct 27, 2009 at 10:10 AM
FACTORYJACK
CERTIFIED EXPERT
Under the right rear seat cushion, lift up on both sides of the seat to remove. remove the vent tube, disconnect the cables(8mm or 5/16), and remove the holdown and bolt(13mm). Shimmy the battery up, and out. Watch that it hasn't leaked. Some have been bad enough to corrode through the floor pan.
