Wipers Always On
Step
Action
Value(s)
Yes
No
1
Did you review the Wiper/Washer System Description and Operation and perform the necessary inspections?
Go to Step 2
Go to Symptoms
2
Turn the ignition switch ON.
Move the wiper switch to all positions and then to OFF.
Disconnect the wiper/washer switch connector.
Do the wipers still operate?
Go to Step 5
Go to Step 3
3
Test for a short to voltage in the pigtail wires leading to the wiper/washer switch. Refer to Circuit Testing and Wiring Repairs in Wiring Systems.
Did you find and correct the condition?
Go to Step 18
Go to Step 4
4
Replace the wiper/washer switch. Refer to Multifunction, Turn Signal, and Hazard Switch Replacement - On Vehicle .
Did you complete the replacement?
Go to Step 18
5
Turn the ignition OFF and then back to RUN.
Go to Step 7
Go to Step 6
6
Replace the wiper motor. Refer to Windshield Wiper Motor Replacement .
Go to Step 18
7
Measure the voltage from the washer input circuit of the wiper/washer switch connector to a good ground.
Does the voltage measure greater than the specified value?
1.0 V
Go to Step 8
Go to Step 11
8
Reconnect the wiper/washer switch connector.
Disconnect the wiper motor connector.
Measure the voltage from the washer input circuit of the wiper motor to a good ground.
1.0 V
Go to Step 10
Go to Step 9
9
May 5, 2009 at 9:50 PM
