2000 Cadillac Deville right front tire vibration
2000 CADILLAC DEVILLE
75,000 MILES • V8 • FWD • AUTOMATIC
I have had a problem with the right front tire vibration, a year ago I suspected it was the rotors, so had these changed and that corrected the problem. The old rotor was warped although I do not do heavy towing, braking or drving. Since then the problem has come back. I had new tires put on a few days ago and did not notice any improvement. Do you know if there is anything more I should have checked out?
Mar 9, 2010 at 6:26 PM
FACTORYJACK
  • 4,159 POSTS
Do you know it is confined to the rh side. Does this vibration only occur when braking, possibly more sever when warmer and/or braking from higher speeds. You could also have a loose outer/inner tie rod ends that could be influencing the vibration.
Mar 9, 2010 at 10:05 PM
