2000 Cadillac Deville Engine Related mEssage on dashboard
2000 CADILLAC DEVILLE
104,000 MILES • V8 • 2WD • AUTOMATIC
VIJAYKBHIMANI
  • 9 POSTS
I am getting this message on dash board afetr I drive about 1 to 2 minutes;
1, service stability system
I reset and it goes away, nothing wrong with ride, it is smooth what is this and how much it will cost to fix? how?
2, Low coolant light comes. Coolant is full and when I reset it goes away. How easy to fix it? How much it cost?
Mar 20, 2008 at 11:07 AM
BUZZSAW
  • 1,198 POSTS
[quote:e3194c9f8e="vijaykbhimani"]Electrical problem
2000 Cadillac Deville V8 Two Wheel Drive Automatic 104000 miles
2, Low coolant light comes. Coolant is full and when I reset it goes away. How easy to fix it? How much it cost?[/quote:e3194c9f8e]
the coolant lite: if the resivior is full you need a coolant lite sensor its in the plastic fill resivior.
you need to scan the codes off and warmer or off and down on the mode button on the heater controls at the same time, with key in the on position. This will put it in diag mode, write them down and post them
Mar 20, 2008 at 6:39 PM
