2000 Cadillac Deville engine hot message
2000 CADILLAC DEVILLE
123,000 MILES • V8 • 2WD • AUTOMATIC
TAYLOR_9825
  • 6 POSTS
I'm getting a engine hot-ac off message. How do i fix this problem since it seem theres enough water in the reservoir
May 18, 2008 at 3:22 PM
LEGITIMATE007
  • 5,121 POSTS
you need to first make sure that you have all of your fluids topped off and then take it to autozone and get a free engine scan and repost your findings
May 18, 2008 at 3:54 PM
BUZZSAW
  • 1,198 POSTS
[quote:38328c5cbf="legitimate007"]you need to first make sure that you have all of your fluids topped off and then take it to autozone and get a free engine scan and repost your findings[/quote:38328c5cbf]
ck you waterpump belt and pump, to scan codes go through your heater, off and warmer or off and down on the mode button at the same time, with your key in the on position
May 21, 2008 at 6:14 PM
TAYLOR_9825
  • 6 POSTS
I took the car to autozone and they said there was nothing wrong. It wasn't giving a code. That went off after a few days. Now I have a check coolant level showing, after I had the thermostat changed. But the car isn't running hot, but the heater is blowing cool air.
Jun 10, 2008 at 4:16 PM
LEGITIMATE007
  • 5,121 POSTS
ok your gonna need to bleed your system out. sounds like you have an air pocket, which is why your not gettin heat. while the engine is cool, take your coolant cap off, and start the car and put the heater on high, let the car come to operating temp. while this is happening the coolant will begin to bubble, that is the air coming out. also be sure to open the over flow container too. after about 10-15 minutes. shut car off and top off coolant. put cap back on. and you should be good to go., if not repeat the steps and do it for just a few minutes longer.
Jun 10, 2008 at 9:04 PM
BUZZSAW
  • 1,198 POSTS
[quote:776518a7f0="taylor_9825"]I took the car to autozone and they said there was nothing wrong. It wasn't giving a code. That went off after a few days. Now I have a check coolant level showing, after I had the thermostat changed. But the car isn't running hot, but the heater is blowing cool air.[/quote:776518a7f0]
if you scaned your codes the way I asked you to do through your heater/AC controls you will get the codes, you dont need autozone, they can only scan PCM codes I need the Body codes, and it is vary hard to get an air pocket in this system, if you have low coolant you still have a leak somewhere
Jun 11, 2008 at 12:43 PM
LEGITIMATE007
  • 5,121 POSTS
but it is still possible , correct?
Jun 11, 2008 at 1:52 PM
BUZZSAW
  • 1,198 POSTS
[quote:4ad11e8bdb="legitimate007"]but it is still possible , correct?[/quote:4ad11e8bdb]
not on this car
Jun 12, 2008 at 7:15 AM
