Air conditioner not working
2000 CADILLAC DEVILLE
89,000 MILES • V8 • 4WD • AUTOMATIC
DEMOUCHET230
i put two cans of freon in my car and the next day it was blowing back warm and i put that leak detector in and i still couldn't find a leak.please help
Feb 23, 2009 at 4:49 PM
This is common when there is a leak in the evaporator which is in the HVAC housing.
However this is not an easy replacement so let's confirm it first. Here are a couple guides that will help with this.
First is a guide on how to find a leak. Next if you still don't find it then we need to pull it down into a vacuum just to confirm it is not holding which shows we are just missing the leak.
https://www.2carpros.com/articles/air-conditioner-leak-detection
However, if it holds a vacuum then you are most likely not getting the compressor to turn on which indicates a different issue so we need to find what the pressure is and go from there.
https://www.2carpros.com/articles/car-air-conditioner-not-working-or-is-weak
I attached a chart below to find out what the pressure is and we need to know what they are and then we can determine next steps.
Please let us know if you have other questions.
Thanks
Aug 1, 2021 at 8:23 PM
