1999 Cadillac Deville shakes
1999 CADILLAC DEVILLE
131,131 MILES • V8 • FWD • AUTOMATIC
SGT E
My car shakes when i hit the brakes. I just recently chanted the tire rod ends. because the boot was torn off on both sides and changed the front rotors but it still shakes. what could be the problem
May 17, 2008 at 4:51 PM
BLACKOP555
  • 10,386 POSTS
back rotors could be bad, is the front end alligned after tie rod changed?
maybe brakes arnt sitting right after rotor changed. try driving in reverse flat level ground, slamming on the brakes that sometimes can get them to sit in.
do that a few times.
May 17, 2008 at 8:16 PM
BUZZSAW
  • 1,198 POSTS
[quote:101070e825="blackop555"]back rotors could be bad, is the front end alligned after tie rod changed?
do that a few times.[/quote:101070e825]
to ck the rear rotors while driving 40 mph + hit the emergency brake,
anytime you change the rotors change the pads or sand them straight the warp will transfer from the pads
May 17, 2008 at 8:51 PM
