1999 Cadillac Deville No Air coming from console cool or ho
1999 CADILLAC DEVILLE
RDEWSNAP
Air Conditioning problem
1999 Cadillac Deville V8 Front Wheel Drive Automatic
A/C is working fine I get cold air from the defrost vent but No AIR FROM THE MIDDLE VENTS and air from the floor vents
Apr 29, 2010 at 2:46 PM
You are dealing with a vacuum leak problem. The vent doors are actuated by vacuum. If the loss of vacuum occurrs, you can't switch direction (defrost is the defalt position). Check under the dash for leaks. Also, with the engine running, you may get lucky and hear a hissing sound where the leak is located.
Let me know if you have other questions, and thanks for using 2carpros.com.
May 4, 2010 at 12:20 PM
