At first I had a continuous Low Refrigerant indication come on. I took it in for repair. They replaced the compressor. After it was fixed each time I drove for 15-20 minutes and the Low refrig would show again. I returned it 6 times to the repair and they do not know.
Note: Each time I pull the power to the battery and reconnect I get cool air for a while then the low refrig indication come back on. When It does blow it's real cool then goes off and showes the indication of low refig! They replaced both AC sencor and no change. Is this possibly a bad connection to the computer. If so where is the computer phycically located on this car so I can check the connections? What are your thoughts....Thanks, Sans
Jul 14, 2010 at 4:41 PM
