I had the cv boots replaced at a sears store.
a day later I saw ,what appeared to be transmission oil on the ground.
I took it to the Cadillac dealer and they said it was a power steering leak. It was further decided it was the rack and pinion seal that was bad. they replaced the rack and pinion.
However they said they found that the trans was leaking badly because of a problem when the CC boots were changed a seal on the axle was damaged by Sears
Sears is replacing the axle. dose this all sound right?
Mar 2, 2009 at 7:23 PM
