1999 Cadillac Deville how do you clear the codes on the das
1999 CADILLAC DEVILLE
JOHNNYO_13
Computer problem
1999 Cadillac Deville V8 Front Wheel Drive Automatic
can you clear the codes from the on board computer somehow ? i know how to get them to read, but how do you remove them???????
Jun 12, 2009 at 8:24 PM
FACTORYJACK
  • 4,159 POSTS
After you get them read, press fan down to scoll through available modules, fan up to select a module, fan down again to scrlll available command, and fan up again to execute. Some modules will only allow reading and clearing codes, where others will show inputs/outputs, and allow override function tests. For example: You have entered diagnostics by pressing off and warmer on the climate panel. After the segment check in goes through a code display, you have a P0603(for instance). Once all the available modules display codes, the display reads "PCM ". You press fan up and the display says "PCM CODES", you press fan down once and the display reads "PCM CLEAR CODES". Press fan up and after a few seconds "PCM CODES CLEAR" displays and your done. You can exit diagnostics by key off, or pressing recirc button(or maybe econ). Fan up, and fan down will accomplish all commands, unless you read data, or perform overrides, and that is another, more lengthy, story.
Jun 12, 2009 at 11:29 PM
