1999 Cadillac Deville Getting trans fluid in coolant
1999 CADILLAC DEVILLE
130,000 MILES • V8 • FWD • AUTOMATIC
ANGELO0118
Got my coolant changed and car was running smooth- I noticed it would spit out coolant through the overflow but the car was not over heating..It did not do it for a week or so then it did it again except this time it had transmission fluid mixed in with it. Service engine light came on with 2 transmission codes - what could cause transmission fluid to get into the coolant. And what type of fix would this be? If it is not transmission fluid I am afraid its the head gasket and its oil, but its a redish color so I think it is transmission fluid. Any ideas would be appriciated
Mar 6, 2009 at 2:03 PM
DETROITBALLER999
you need a new radiator . the trans fluid circulates thru the radiator around the coolant very easy fix u can get a used radiator for around 50 bucks. also u should flush the coolant system.
Mar 11, 2009 at 9:32 PM
