1999 Cadillac Deville column shifter
1999 CADILLAC DEVILLE
79,000 MILES • V8 • FWD • AUTOMATIC
KENNROZ
the shifter is hard to operate to get in gear.no leaks ,no repair history.it will go into gear and the transmission runs fine.it seems worse when its colder this is my wifes car,not used too often.
Dec 5, 2007 at 6:01 PM
BUZZSAW
  • 1,198 POSTS
[quote:4f2f4c074d="kennroz"]Transmission problem
1999 Cadillac Deville V8 Front Wheel Drive Automatic 79000 miles
the shifter is hard to operate to get in gear.no leaks ,no repair history.it will go into gear and the transmission runs fine.it seems worse when its colder this is my wifes car,not used too often.[/quote:4f2f4c074d]
ck the cable on the trans, its under the master cylinder, take off the 13 mm bolt and then opreate the shifter from inside, that will tell you which side its comming from
Dec 10, 2007 at 1:01 PM
