1999 Cadillac Deville Battery
1999 CADILLAC DEVILLE
85,000 MILES • V8 • FWD • AUTOMATIC
GIDEON YEFET
How to replace the battery on 1999 Cadillac DeVille d'Elegance Sedan
Aug 9, 2009 at 4:40 PM
FACTORYJACK
  • 4,159 POSTS
In the rh front corner of the engine compartment, remove negative and positive cable(in that order). Remove the 13mm holdown nut and block, lift the battery out. Reverse procedure to install. The cable bolts are 5/16", or 8mm. Nothing else is needed, other than setting the clock.
Aug 10, 2009 at 12:56 AM
