It all depends on how involved you want to get, and what your diagnostic capabilities are. Do you have a test light? Another thing that will play a part is the fact that there are two types of systems in 98. There is a rain-sensing system, and just a basic pulse delay type system. Is this a base deville, and does the word auto appear on your wiper stalk in the delay area? Also does the washer turn on when requested? I will forward you the diagnostic chart for inop in all modes(pulse system), let me know if it applies, and if you need more info.
Wipers All Modes Inoperative
Step
Action
Value(s)
Yes
No
1
Was the Wiper/Washer System Check performed?
Go to Step 2
Go to Wiper/Washer System Check
2
Inspect the WIPERS fuse A9 for an open.
Is the fuse open?
Go to Step 3
Go to Step 4
3
Replace the WIPERS fuse.
Is the replacement complete?
4
Disconnect the wiper/washer switch connector C202.
Turn ignition switch ON.
Connect a test light from connector C202, terminal E5 to ground.
Is the test light on?
Go to Step 16
Go to Step 5
5
Connect a test light from Accessory Relay, terminal A1, to ground.
Go to Step 6
Go to Step 11
6
Connect a test light from Accessory Relay, terminal A3, to ground.
Go to Step 7
Go to Step 12
7
Connect a test light from Accessory Relay, terminal B1 to terminal A3.
Go to Step 8
Go to Step 15
8
Inspect CKT 143 for an open or poor connection between connector C202 and the Accessory Relay.
Was an open or poor connection found?
Go to Step 9
Go to Step 10
9
Repair the open or poor connection in CKT 143.
Is the repair complete?
10
Replace the the Accessory Relay.
11
Repair the open in CKT 1040 or the power feed circuit to the WIPERS fuse.
12
Inspect the ACC fuse C13 for an open.
Is the fuse open?
Go to Step 13
Go to Step 14
13
Replace the ACC fuse.
14
Repair the open in CKT 43 or the power feed circuit to the ACC fuse.
15
Repair the open in CKT 50.
16
Disconnect the wiper motor connector C2.
Connect the test light from connector C2, terminal C to battery voltage.
Go to Step 18
Go to Step 17
17
Repair the open in CKT 750.
18
Reconnect the wiper/washer switch connector C202.
Disconnect the wiper motor connector C1.
Connect the test light from wiper motor connector C1, terminal C, to ground.
Go to Step 22
Go to Step 19
19
Inspect for an open in CKT 95.
Was an open found?
Go to Step 20
Go to Step 21
20
Repair the open in CKT 95.
21
Replace the wiper/washer switch. Refer to Multifunction Turn Signal Lever Replacement - On Vehicle .
22
Set the wiper switch to LO.
Connect the test light from the wiper motor connector terminal, B, to ground.
Go to Step 25
Go to Step 23
23
Inspect for an open in CKT 91.
Was an open found?
Go to Step 24
Go to Step 21
24
Repair the open in CKT 91.
25
Inspect for continuity between wiper motor connector C1, terminal A, and connector C2, terminal B, with a J 39200.
Is there continuity?
Go to Step 26
Go to Step 29
26
Inspect for a poor connection at wiper motor connector C2, terminal A.
Was a poor connection found?
Go to Step 28
Go to Step 27
27
Replace the wiper motor. Refer to Windshield Wiper Motor Replacement .
28
Repair the poor connection.
29
Inspect for an open in CKT 196.
Was an open found?
Go to Step 30
Go to Step 21
30
Repair the open in CKT 196.
Feb 25, 2010 at 10:18 PM
