I have the tcs code that says the right rear wheel speed sensor is not reading so it is causing my abs and traction control lights to stay on. I replaced the rear wheel bearing hub whiech has the speed sensor on it but still have the same problem what can I do to fix this problem I even installed anouther hub just in case I had a bad part but that was not it.
Dec 8, 2009 at 9:20 PM
