Electrical problem
1998 Cadillac Deville V8 Front Wheel Drive Automatic
i think that my rfa is not receiving the signal from my transmitter. i first found a broken solder point inside my transmitter. and a guy at the tv repair shop resoldered it. after i disconnected the negative battery terminal and restalled it everything was fine. about teen days later the remote with new battery would not do anything. at least once a week when open the door with the key to leave work the hornstarts to blow and i can not stop it unless i disconnect the battery and then hold down the power door lock switch. i bought a new transmitter but i am uable to program it because my digital display never shows anything but rfa code? and clear rfa codes. i do the fan up and down stuff but i never get the override rfa stuff that the manual states i am supposed to get. also, sometimes over night or just parked for a couple of hours i have no power until i turn on the key. the next issue is with the ac. sometimes i comes on and all is well. then sometimes it comes on and goes right back off only to restart or not come back on at all. last june i had the high pressure switch replaced and the system charged it gets really hot n so.fla in the summer. please help!!!!!!!!
Apr 30, 2008 at 11:27 PM
