[quote:e1548d08b3="wabashrat"]Other Category problem
1998 Cadillac Deville V8 Two Wheel Drive Automatic 118000 miles
How do you get the to the drivers side window motor for replacement. I don't see any srews to even remove the outer panel. Any help would be appriciated[/quote:e1548d08b3]
I would say its the switch, In my 5 years as a tech I vary rarely replaced window motors, you need to hit the switch hard with your finger, while looking at the dome lite, watch for it to dim. if it doesnt its the switch
you will bust the door panel if you listen to ED, there are no plastic fasteners, its hooked in
Mar 10, 2008 at 1:36 PM
