1998 Cadillac Deville a/c will not turn on
1998 CADILLAC DEVILLE
113,000 MILES • V8 • FWD • AUTOMATIC
DONDOG6391
I stored my '98 Deville for about 6 months and put it on a trickle charger. When I returned six months later the battery was dead so I charged it overnight and had it replaced at Adv Auto Parts and it runs ok. The message center said refrigerant low/ac off. I put some in (about 40 pounds pressure} but the ac still doersn't come on , the message center still says low refridgerant/ac off. When I press the econ/auto button it switches to auto but goes back to econ as soon as I release the button. What do I do to get the ac working? Thanks in advance.
Dec 21, 2008 at 9:53 AM
2CARPRO JACK
  • 11,533 POSTS
You have to clear the codes before it will turn on.
Key on engine off
Press "warmer and off" at the same time, hold down until screen changes
press fan "low" until ACM appears on thescreen
Press fan "hi" until "ACM codes" appears
Press fan "low" until "clear ACM codes" appears
Press fan "hi" until ACM codes clear is on the screen.
If the system is working properly at this point the compressor will come on
Dec 23, 2008 at 9:03 AM
