My 98 Deville is starting to overheat and loose coolant as well. I am sure it is the head gasket because my car symptoms are similar to others who have experienced head gasket difficulties. Would this problem resurface if the timeserts are installed at a Cadillac dealership? I also have an oil leak, which I think is associated with the head gasket problem. Would a bad head gasket make the Northstar leak oil as well? I had a 98 Dodge Neon and the head gasket was bad on it and it leaked oil as well. After the Neon head gasket was repaired, it stopped leaking oil. My car only has 79,000 miles on it, so I think it is worth the repair. Does the transmission usually fail after the head gasket goes bad?
Do you have any advice on what I should do?
Jan 11, 2010 at 12:06 AM
