1997 Cadillac Deville My car pulls to one side
1997 CADILLAC DEVILLE
170,000 MILES • 6 CYL • FWD • AUTOMATIC
BSUMLING
I have a 1997 Cadillac Deville and it has steering problems. When I drive my car it pulls to the left. I thought it needed a wheel alinement so I took it to a shop. I was told that my wheel bearings were bad and they cant do a wheel alinement until they replaced the wheel bearings. Most people tell me your wheel bearing are bad when thay make sounds but I dont hear anything, it just pulls. I took it to a tire shop and they said my tire had a good tread on the inside and where going to turn them inside out and balance the tire.They did but then it pulled to the other side. Does wheel bearing cause your car to pull or do I need new tire and a wheel alinement
Feb 5, 2008 at 12:19 AM
BUZZSAW
  • 1,198 POSTS
[quote:15eeb628aa="bsumling"]Steering problem
1997 Cadillac Deville 6 cyl Front Wheel Drive Automatic 170000 miles
I have a 1997 Cadillac Deville and it has steering problems. When I drive my car it pulls to the left. I thought it needed a wheel alinement so I took it to a shop. I was told that my wheel bearings were bad and they cant do a wheel alinement until they replaced the wheel bearings. Most people tell me your wheel bearing are bad when thay make sounds but I dont hear anything, it just pulls. I took it to a tire shop and they said my tire had a good tread on the inside and where going to turn them inside out and balance the tire.They did but then it pulled to the other side. Does wheel bearing cause your car to pull or do I need new tire and a wheel alinement[/quote:15eeb628aa]
if the tires arnt wearing, align is good, a tire can make it pull one way or the other, instaed of turning tire inside out cross rotate them, put left on right side, in the front only, drive it and see, if a wheel bearing was bad your right it would make noise or the abs sensoe goes bad, something in that nature, they were trying to get you
Feb 5, 2008 at 12:49 PM
