1997 Cadillac Deville how to recharge the air conditioner
1997 CADILLAC DEVILLE
63,000 MILES • 6 CYL • 2WD • AUTOMATIC
PRAIRIEDOC
the ac temp is 62degrees. No other problems. Can I refill the AC myself?
Jul 18, 2010 at 4:07 PM
EDWARD.S
  • 166 POSTS
Hi, If You Do not UnderStand automobile Ac Systems ,Please Do Not Try To Fill It Up , Many People Have Been Serious Injured. It's Not worth Hurting Yourself.Take It To a mechanic.
Hope This Helps You.
Edward S.
Jul 18, 2010 at 4:30 PM
CARADIODOC
  • 34,306 POSTS
Hi prairiedoc. Welcome to the forum. Edward.S is right. Escaping refrigerant will freeze eyeballs and cause frostbite. But beyond the extensive safety precautions taken by professionals, there is no way to know how much charge is still in a GM car. The only way to fill the system properly is to completely recover the remaining refrigerant, then pump in the correct measured amount as listed on the sticker under the hood. Even using gauges to measure system pressures is not accurate. Fords and Chryslers use sight glasses to tell when the system is full, but even those are only accurate on Chryslers.
Duct temperatures in the high 40 degree range is common but 62 degrees is not that bad. Automotive AC systems are only designed to lower air temperature 20 degrees because they have to handle a huge volume of air, unlike your home refrigerator. The real comfort comes from removing the humidity.
caradiodoc
Jul 18, 2010 at 5:14 PM
PRAIRIEDOC
Thanks guys. 106 degree temps on the farm must be getting the better of me.
Jul 18, 2010 at 7:00 PM
