[quote:d3cc8c9386="jarvismjohnson"]yes, it does have an adjustment knob on the pass. door console, but it still blows cold no matter where that dial is set. driver side still hot no matter where pass. dial is set[/quote:d3cc8c9386]
ck the freon level, you need a guage for AC. it runs about 28 to 30 psi on the guage, if its lower than that its low and needs a recharge, if its higher its got problems like a blockage, probally the orfice tube
you can also pull the codes for me to see if there is any AC codes in it
push off and warmer on the heater controls at the same time, with the key in the on position, look in the message center on the Insterment panel for the codes and post them here
Apr 21, 2008 at 4:17 PM
