how do you remove the water pump pulley from the camshaft ??????????? is it pressed on or is threaded on
Nov 6, 2010 at 11:59 AM
FACTORYJACK
CERTIFIED EXPERT
It is pressed on, real similar to a power steering pump pulley. I believe the only difference is the thread size in the camshaft is a bit smaller. I have a universal power steering pulley remover that I use, that has several adapters.
