I will include you all fastener specs. My question to you before you waste a gasket, did thread inserts get installed in the block. Typically when head gaskets fail on these it is a result of lost bolt torque due to pulled threads. There is a procedure to repair these using what is called a timesert, and is recommended that they be put in all holes at the same time. If you only have one head off, you should do all holes on that side. Here are the specs:
Fastener Tightening Specifications
Application
Specification
Metric
English
Air Conditioning Compressor Bracket to Lower Crankcase Lock Nut
30 N·m
22 lb ft
Air Conditioning Compressor Bracket to Lower Crankcase Stud
25 N·m
18 lb ft
Air Conditioning Compressor to Block and Bracket
50 N·m
37 lb ft
Air Conditioning Compressor Mounting Bracket to Compressor
25 N·m
18 lb ft
Brace--Left Bank (Long)
75 N·m
55 lb ft
Brace--Left Bank (Short)
50 N·m
37 lb ft
Braces--Right Bank
50 N·m
37 lb ft
Camshaft Bearing Cap
12 N·m
106 lb in
Camshaft Chain Guide Access Plug
4.5 N·m
39 lb in
Camshaft Cover
10 N·m
89 lb in
Camshaft Drive Chain Guide Bolts
25 N·m
18 lb ft
Camshaft Drive Chain Tensioner to Block
25 N·m
18 lb ft
Camshaft Seal Retainer to Cam Cover (Left Hand Head)
3 N·m
27 lb in
Camshaft Sprocket
120 N·m
89 lb ft
Catalytic Converter to Exhaust Manifold Rear Pipe
50 N·m
37 lb ft
Connecting Rod Bolt
First Pass
30 N·m
22 lb ft
Second Pass
Back off to zero
Third Pass
25 N·m
18 lb ft
Final Pass
+110 degrees
Coolant Temperature Sensor
20 N·m
15 lb ft
Crankshaft Balancer Bolt
First Pass
50 N·m
37 lb ft
Final Pass
+120 degrees
Crankshaft Position Sensor
10 N·m
89 lb in
Cruise Control Bracket to Throttle Body Bracket
12 N·m
106 lb in
Cylinder Block Coolant Heater - Right & Left
10 N·m
89 lb in
Cylinder Head Bolt (M11)
First Pass
40 N·m
30 lb ft
Second Pass
+70 degrees
Third Pass
+60 degrees
Final Pass
+60 degrees (190 degrees Total)
Cylinder Head Bolt (M6)
12 N·m
106 lb in
Cylinder Head Plug
80 N·m
59 lb ft
Cylinder Head Plug (Oil Gallery)
12 N·m
106 lb in
Cylinder Head Plug (Soc Hex)
5.5 N·m
49 lb in
Drive Belt Idler Pulley
50 N·m
37 lb ft
Drive Belt Tensioner
50 N·m
37 lb ft
EGR Pipe (to Intake Manifold)
25 N·m
18 lb ft
EGR Tube (to Water Crossover)
25 N·m
18 lb ft
EGR Tube to Intermediate Pipe Nut
60 N·m
44 lb ft
EGR Valve
25 N·m
18 lb ft
Engine Flywheel Bolt
First Pass
15 N·m
11 lb ft
Final Pass
+50 degrees
Exhaust Manifold Pipe to Cylinder Head
25 N·m
18 lb ft
Exhaust Manifold Pipe to EGR Tube
60 N·m
44 lb ft
Exhaust Manifold Pipe to Exhaust Manifold Rear Pipe
25 N·m
18 lb ft
Exhaust Manifold Pipe to Lower Crankcase
25 N·m
18 lb ft
Exhaust Manifold Rear Pipe to Right Manifold
40 N·m
30 lb ft
Exhaust Manifold to Cylinder Head Lock Nut
25 N·m
18 lb ft
Exhaust Manifold to Cylinder Head Bolt
25 N·m
18 lb ft
Flywheel Housing Cover Bolt
9 N·m
80 lb in
Front Cover Bolt
10 N·m
89 lb in
Generator and Air Conditioning Bracket to Block Bolt
50 N·m
37 lb ft
Generator Bracket to Block (Rear Bolt)
47 N·m
35 lb ft
Generator Bracket to Block (Rear Nut)
38 N·m
28 lb ft
Generator to Bracket (Front Lower Bolt)
50 N·m
37 lb ft
Generator to Bracket (Front Upper Bolt)
50 N·m
37 lb ft
Generator to Bracket (Rear Bolt)
50 N·m
37 lb ft
Ignition Module Bolt (to Cam Cover)
12 N·m
106 lb in
Intake Manifold Bolt
10 N·m
89 lb in
Intermediate Sprocket Retaining Bolt
60 N·m
44 lb ft
Intermediate Sprocket Shaft Bolt
10 N·m
89 lb in
Knock Sensor
20 N·m
15 lb ft
Lift Bracket--Front
50 N·m
37 lb ft
Lift Bracket--Right Rear
50 N·m
37 lb ft
Lower Crankcase to Block (M8 x 1.25)
30 N·m
22 lb ft
Lower Crankcase Bolt/Stud (In Sequence) (M10 x 1.5)
First Pass
20 N·m
15 lb ft
Final Pass
+65 degrees
Oil Cooler lines to Oil Cooler
18 N·m
13 lb ft
Oil Cooler Lines to Oil Filter Adapter
18 N·m
13 lb ft
Oil Filter Adapter
16 N·m
12 lb ft
Oil Filter Adapter Plug w/Oil Cooler
20 N·m
15 lb ft
Oil Filter Adapter Plug w/o Oil Cooler
18 N·m
13 lb ft
Oil Level Indicator Tube
10 N·m
89 lb in
Oil Level Sensor
20 N·m
15 lb ft
Oil Manifold Plate to Lower Crankcase
10 N·m
89 lb in
Oil Pan Bolt
First Pass
8 N·m
71 lb in
Final Pass
12 N·m
106 lb in
Oil Pan Brace
50 N·m
37 lb ft
Oil Pan Drain Plug
20 N·m
15 lb ft
Oil Pump Suction Pipe (Lock Nut)
25 N·m
18 lb ft
Oil Pump to Lower Crankcase
First Pass
10 N·m
89 lb in
Final Pass
+35 degrees
Oxygen Sensor
40 N·m
30 lb ft
Power Steering Pump (to Bracket)
25 N·m
18 lb ft
Power Steering Pump Bracket (to Block)
50 N·m
37 lb ft
Starter (to Block)
30 N·m
22 lb ft
Starter Motor (Lock Nut)
10 N·m
89 lb in
Thermostat Outlet to Water Pump Cover
10 N·m
89 lb in
Torque Converter to Flywheel Bolt
Jun 13, 2009 at 2:06 PM
