i accidentally poured a lil bit of oil into my antifreeze overfill, will this cause any mechanical problems?
Apr 23, 2010 at 8:37 AM
FACTORYJACK
CERTIFIED EXPERT
Should not cause any mechanical problems. Worst case is that it softens the rubber hoses. If it was a small amount, had you known it before running, and tried to get it out? It will stay in the highest point in the system, which is usually the reservoir.
