1996 Cadillac Deville fuel filler pipe
1996 CADILLAC DEVILLE
113,000 MILES • V8 • FWD • AUTOMATIC
TRACYMIKE
When filling the tank gas over flows when full. also can smell gas vapors?
May 21, 2008 at 11:05 AM
BUZZSAW
  • 1,198 POSTS
[quote:cd5fb1120e="tracymike"]Smells problem
1996 Cadillac Deville V8 Front Wheel Drive Automatic 113000 miles
When filling the tank gas over flows when full. also can smell gas vapors?[/quote:cd5fb1120e]
has a fuel pump ever been done to this car?
May 21, 2008 at 5:58 PM
TRACYMIKE
[quote:ee880e7092="Buzzsaw"][quote:ee880e7092="tracymike"]Smells problem
When filling the tank gas over flows when full. also can smell gas vapors?[/quote:ee880e7092]
ha s a fuel pump ever been done to this car?[/quote:ee880e7092] I donot know if fuel pump was removed when tank is fuel runs out of fill pipe?
May 21, 2008 at 9:01 PM
BUZZSAW
  • 1,198 POSTS
[quote:3f71b8db99="tracymike"][quote:3f71b8db99="Buzzsaw"][quote:3f71b8db99="tracymike"]Smells problem
When filling the tank gas over flows when full. also can smell gas vapors?[/quote:3f71b8db99]
ha s a fuel pump ever been done to this car?[/quote:3f71b8db99] I donot know if fuel pump was removed when tank is fuel runs out of fill pipe?[/quote:3f71b8db99]
when a new fuel pump is installed sometimes the gasket slips out and causes a leak when full, do you have a ck engine light on? the evap sys should throw a code because the sys is not pressureizing if you have a leak, the dealer has a machine that puts a smoke charge into the gas tank through this sys to find leaks
May 23, 2008 at 8:04 AM
