1995 Cadillac Deville water pump
1995 CADILLAC DEVILLE
RMOOREV1
  • 4 POSTS
Engine Cooling problem
1995 Cadillac Deville V8 Automatic
i replaced the water pump but it is still leaking after running could it be the thermistat.
Dec 7, 2008 at 4:53 PM
i replaced the water pump but it is still leaking -What do you meant by this-Do you have a physical leak within the engine/hoses/radiator?????? Please! explain
Dec 7, 2008 at 5:04 PM
RMOOREV1
  • 4 POSTS
it leaks around the water pump housing .like its under to much pressure and spays out the side.
Dec 7, 2008 at 10:41 PM
Try retorquing it -don't work you have to remove it and clean off the mating surfaces good get another gasket for it and apply RTV
Dec 8, 2008 at 5:09 AM
