Was the belt replaced to address squealing? A few things come to mind to try and narrow this down. You could have coolant on a pulley, or the belt, and the residue will cause squealing. The belt could be wrong(too long), or the tensioner weak causing a lack of belt tension. You could also have pulleys out of alignment, belt not running true. Try dribbling, or spraying some non-oil based liquid on the belt when running to see if squeal changes. Water alone may make a change. A shot of carb or brake cleaner works well, as it has a fast evaporation rate and leaves little or no residue. You could also have an accessory seizing up. If/when you have the belt removed, start it and see that the squeal is gone. With it shut down, spin all driven accessories(P.S., Idler, Tensioner pulley, Alternator, A/C, Water Pump) and see that they spin freely.
Apr 2, 2009 at 9:22 PM
