1995 Cadillac Deville Replacing Brake Line
1995 CADILLAC DEVILLE
10,300 MILES • V8 • FWD • AUTOMATIC
RONALDRLAVERDE
I am replacing a new Brake Line from the left rear bracket that attaches to the brake hose all the way to the front Brake Pressure Modulator. I cannot track the existing line to the BPM. I am leaving the old line. It is hard to tell where the line attaches to the BPM. I cannot find a sequence diagram for the modulator. Do you know where the left rear line attaches?
Thank You,
Ron LaVerde
Jul 6, 2009 at 9:50 PM
MHPAUTOS
  • 31,937 POSTS
Hi there,
Thank you for the donation,
I have looked extensively and have not come up with a good view of this, the best i can suggest is to undo the lines one at a time and blow down them you will know when you hit the correct one, as you will have to re bleed all the brakes anyway this may be the best option.
Mark (mhpautos)
Jul 12, 2009 at 10:35 PM
RONALDRLAVERDE
The job has been finihed. After not receiving answer for a while. I decided to hook an air pump to the rear side and blow air through to find out which line I needed to reolace
Jul 13, 2009 at 9:10 AM
