1994 Cadillac Deville PCM
1994 CADILLAC DEVILLE
218,000 MILES • V8 • 2WD • AUTOMATIC
JJOHNSTON2
  • 6 POSTS
I Ran the on-board diagnostic and it doesn't recognize the pcm. It shows "PCM?". Took to a shop because it failed an AIMs test and he said he couldnt connect to my computer. WHat should i do?
Mar 12, 2010 at 5:50 PM
FACTORYJACK
  • 4,159 POSTS
This is a 94, and the vehicle does run? After you press off and warmer, and it does the segment check, it displays 'PCM?'? It would display that after it went through displaying all the codes. If it didn't recognize the PCM, it would either not even be there, or it would display 'no pcm data'. At any rate, when it displays 'PCM?', press fan up. It should change to PCM codes, PCM data, PCM overrides, or PCM clear codes. Fan down will scroll through the choices, fan up will select. See what that does.
Mar 14, 2010 at 1:18 AM
