1993 Cadillac Deville Windows, Climate Control, and Fuel Ga
1993 CADILLAC DEVILLE
DAZACHATTACK17
Electrical problem
1993 Cadillac Deville V8 Two Wheel Drive Automatic
As I made a turn recently my car's electrical for my windows, climate control, and fuel gauge display shut off. At the time my car didn't lose power so I don't think there's a problem with the battery connection. Later I went on to check all the fuses inside the car at both the box underneath the driver and passenger's side. Does anyone else know a possible way to fix this? Also my Check Engine and Antilock brake lights stay on now.
Sep 24, 2009 at 1:18 AM
MERLIN2021
  • 17,250 POSTS
Sounds like either a ground wire, connector problem, or ignition switch, Start by checking grounds, then connectors by pulling them apart and re joining them look for bent or pushed out pins while they are seperated. Ignition switch(whitePlatic) piece not the lock cylinder, would be the last but I would see if you can locate the continuity table to test it, I looked but dont have it. I go to the parts store and browse thier books until I find what I need. You can also read the codes. I will email you the self diagnostic manual. so be on the lookout!
Sep 24, 2009 at 4:00 PM
