1993 Cadillac Deville Blower Motor
1993 CADILLAC DEVILLE
ESTREETBAND
Heater problem
1993 Cadillac Deville V8 Front Wheel Drive Automatic
Blower Motor runs constantly even with key not in the ignition. Blower Motor speed cannot be adjusted, cannot be turned off and no heat is blowing out. Only way to stop the motor is to disconnect it or the battery. Thermostat seems to be fine, appears to be no damage to heater core.
Mar 19, 2009 at 11:56 AM
Check the blower motor relay could be sticking
Mar 19, 2009 at 3:45 PM
FACTORYJACK
  • 4,159 POSTS
Shorted power module under the hood, mounted in the top of the HVAC case, just to the right(passenger) center of the engine compartment. You may have to lift the plastic(relay center) cover at the RH side, if it is still there.
Mar 20, 2009 at 11:25 PM
