Fuel data center
1992 CADILLAC DEVILLE
VLADYVLAD
Electrical problem V8 Front Wheel Drive Automatic 156000 miles
my fuel data is blank when I turn the car on so I can never tell how much fuel I have. I want to avoid costly repairs, I just want to know what can I do to fix it? Do you think it might be the BCM can you reset the BCM. And I checked and rechecked all the fuses
Dec 17, 2009 at 3:38 PM
FACTORYJACK
  • 4,159 POSTS
Yes it could be the BCM, it could be the fuel data center. Fuse #7 is in the I/P fuse block, it supplies ignition power to FDC. Other than that, all of the inputs for the vacuum fluorescent display are from the data line. Labeled as the ECM/BCM data line. If you have a source for some used parts, a u-pull it, or other salvage yard, that may be an option.
Dec 18, 2009 at 11:55 PM
VLADYVLAD
I not really sure i reset the bcm do you know where it's located.
Dec 20, 2009 at 7:31 AM
The BCM is located behind the glovebox. Here is a diagram so you can see (below)
Nov 16, 2017 at 11:22 AM
