1991 Cadillac Deville Air con- heater
1991 CADILLAC DEVILLE
102,000 MILES • V8 • FWD • AUTOMATIC
SALSABOY7
  • 5 POSTS
After running the car that has been laid up for 5 months the air con will not turn off even after removing the key and walking away so i have to remove the fuse to stop it.
Any suggestions
Nov 26, 2008 at 11:07 AM
A73LEWIS
someone has ran a continuous hot lead to blower motor disconnect and rehook correctly.
Feb 7, 2009 at 9:38 PM
SALSABOY7
  • 5 POSTS
Thank you for your reply.
The car had not been hot wired in any way but i eventually sorted it out by letting the engine run for a considerable amount of time and let the computer reset itself and that seemed to cure the problem although i did keep playing with the controls so one or other of these operations sorted the problem.
Now i am keeping the battery on charge continuously to avoid it going flat.
Regards, Salsaboy7
Feb 9, 2009 at 4:27 AM
