1991 Cadillac Deville
1991 CADILLAC DEVILLE
86,000 MILES • V8 • FWD • AUTOMATIC
NEEDURHELP
I was smelling radiator fluid and when i turned my AC on. The next day my heater was blowing cool air and I was leaking fluid through the floor vents inside and outside of the car. No sound of overheating or no steam coming from under the hood, however the hose was very hot. What should I do or what could be wrong?
Feb 26, 2009 at 9:18 AM
FACTORYJACK
  • 4,159 POSTS
If you have coolant leaking on floor of car, you have a heater core that is leaking. This would not explain the coolant outside the car so my guess is, you have an external leak. You should probably replace the core and have the cooling system pressure tested.
Feb 26, 2009 at 9:39 PM
