1990 Cadillac Deville vibration, shimmy
1990 CADILLAC DEVILLE
21,100 MILES • V8 • 2WD • AUTOMATIC
HARR5251
have a vibration, shimmy problem between 20-49 mph. Seems when accelerating there is a bad vibrations though the front end is about to come out.. seems like levels off after 40/45. Had front tires balanced , but still have problems.. am concerned it may be cv joints or lower ball joints, not sure,, any suggestions please,, thanks
Jan 25, 2008 at 1:01 PM
BUZZSAW
  • 1,198 POSTS
[quote:5edb99b296="harr5251"]Interior problem
1990 Cadillac Deville V8 Two Wheel Drive Automatic 211,00 miles
have a vibration, shimmy problem between 20-49 mph. Seems when accelerating there is a bad vibrations though the front end is about to come out.. seems like levels off after 40/45. Had front tires balanced , but still have problems.. am concerned it may be cv joints or lower ball joints, not sure,, any suggestions please,, thanks[/quote:5edb99b296]
have you hit anything, did they look for a bent rim, or bad tire? ck tie-rods, outer and inner, inner is part of the rack( steering-gear ) also make sure the gear isnt loose
Jan 25, 2008 at 3:57 PM
